Spuštěn nový vzhled portálu CADfórum.
Již 10.000+ CAD tipů. Přes 117.000 registrovaných u nás, celkem 1.089.000 registrovaných (CZ+EN), přes 54.000 CAD/BIM bloků. Vyzkoušejte nový Inženýrský kalkulátor. Příkazy a proměnné AutoCADu 2026.
Téma uzavřenoUpdate 2 pro Inventor 2014 se SP2
Arkance Systems
Bodů: 21873
Přímý odkaz na tuto zprávu Téma: Update 2 pro Inventor 2014 se SP2
    Zasláno: 29.srp.2014 v 16:13
Byl uveden "Update 2" pro Autodesk Inventor 2014 s nainstalovaným Service Packem 2. Stahujte zde.
Přehled oprav v Update2:
Description of the Issues Addressed in Update 2 for Inventor 2014 Service Pack 2
  • 1517-992: Inventor hangs when saving a large assembly as Catia V5.
  • 1518-199: The setting of template for assembly in make component configuration is not retained.
  • 1517-970: Change Size of Content Center part results in inaccurate parameters.
  • 1516-370: iFeature does not update correctly when the reference sketch changes.
  • 1517-578: Parameters in dependant copied iFeature do not update correctly editing the base iFeature.
  • 1518-417: Import Parameters functionality does not update all the parameters as expected.
  • 1420-905: Incorrect Master Mass is calculated when generating Shrinkwrap.
  • 1515-962: Corner not detected on sheetmetal flange created with thicken command.
  • 1514-506: Poor graphics performance with custom DPI size.
  • 1516-669: Stress Analysis – Unable to select face for FEA loads and constraints.
  • 1518-676: Stress Analysis - Load directions based on existing faces are incorrect and cannot be changed.
  • 1518-703: The model displays too brightly after migrating the customized lighting styles to the Inventor default styles.
  • 1517-471: Moment of Inertia is calculated to negative value if modifying the Mass value manually.
  • 1518-347: Feature creation becomes unresponsive after open and close component multiple times during a single Inventor session.
  • 1518-402: Drawing section view becomes corrupt after update.
  • 1507-142: Unexpected exit in XLayerExternalResolver::ResolveFile() when running VBA.
  • 1517-349: Unexpected exit when updating second derive part after deleting the geometry in sketch block within base part.
  • 1518-794: Unexpected exit when working with part file in non-English version.
  • General stability enhancements
ARKANCE CZ - arkance.world
Tip 9519:Nefunguje mi Inventor 2013, 2012 nebo 2011 po upgrade na Windows 8.1
Tip 8760:Musím instalovat SP1 před instalací SP2?
Tip 9510:Chyba po spuštění Inventoru - Průzkumník Windows přestal pracovat, nebo Chyba aplikace.
Tip 6356:Ukládání výkresu z Architecture 2009 do verze DWG2004 je pomalé.
Tip 7983:Záporná plocha křivky.
