Discussion forum
CAD discussion |
Error Message trying to use site. |
Post Reply |
Author | |
Vladimir Michl
Topic: Error Message trying to use site. Posted: 22.Feb.2012 at 11:49 |
No, the problem really exists :-) Working hard to find the source of it.
It should be partially fixed now.
Vladimir Michl (moderator)
heinsite
Senior Member Joined: 05.Feb.2009 Location: United States Using: AutoCAD 2014 Status: Offline Points: 640 |
Posted: 22.Feb.2012 at 04:05 |
I'm probably jinxing myself now, but I haven't seen this even once.
I guess it just doesn't like you, John.
Dave
Dave Hein, P.E.
Hawaii District Engineer Kona International Airport AutoCAD Certified Professional Autodesk Expert Elite |
Vladimir Michl
Posted: 21.Feb.2012 at 18:35 |
We aware of the performance problems in the last days. Trying to fix them both on the software side and by a hardware upgrade.
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 21.Feb.2012 at 18:09 |
Server Error in Forum Application
An error has occured while connecting to the database. Please contact the forum administrator. Support Error Code:- err_SQLServer_db_connection File Name:- common.asp Error details:- Provider Unspecified error I'm getting more and more of these each time I visit the site. What's up? This site seems to have its fair share of operational glitches. Sometimes it is soooooo slooooooow as to discourage its use. Time to move to a new server? |
<<AutoCAD 2015>> |
Post Reply | |
Tweet
This page was generated in 0,465 seconds.
