Discussion forum
CAD discussion |
ADDLEN.VLX , need LSP version |
Post Reply |
Author | |
burzek
Newbie Joined: 26.Oct.2016 Location: Turkey Using: zwcad Status: Offline Points: 3 |
Topic: ADDLEN.VLX , need LSP version Posted: 26.Oct.2016 at 12:29 |
Hi,
I was using "AddLen - add total length of lines and curves by layers (VLX for AutoCAD)" in Zwcad application. However 2017 version does not support VLX anymore. I suppose this site is the author of the VLX file. Is it possible to upload ADDLEN as LSP file, so I can appload it into Zwcad. Please help, Best Regards... |
rebellio
Senior Member Joined: 04.Mar.2009 Location: Netherlands Using: Autocad 2018 Status: Offline Points: 125 |
Posted: 26.Oct.2016 at 12:43 |
burzek
Posted: 26.Oct.2016 at 12:48 |
Hi,
Thank you for the reply. I had tried it. It works however, it just displays the total length. addlen.vlx , puts the total length by items in a nice format in a sdf file. Such as 20+30+40=90 TOTAL Length So I can copy it and put it to a document easily. Is there anyway modify the lsp file to do the same? Thanks and Regards. |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 26.Oct.2016 at 13:21 |
That comes under the heading, "Don't give me what I asked for, give me what I need." LOL
<<AutoCAD 2015>> |
rebellio
Posted: 26.Oct.2016 at 14:49 |
LOL
rebellio
Posted: 26.Oct.2016 at 15:39 |
Hi
Found a crazy freeware tool. dont now if vba is an option in Zwcad 2017. It is worth to check this one out. Maybe this is more than you need lol Regards Edited by rebellio - 26.Oct.2016 at 16:32 |
John Connor
Posted: 26.Oct.2016 at 16:16 |
The OP is using ZWCAD not AutoCAD.
<<AutoCAD 2015>> |
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 632 |
Posted: 26.Oct.2016 at 16:28 |
Here is something that at least uses the same name in a .LSP filetype [whether it's the same functionality, I couldn't say]. Or maybe you can use or modify one of the several similar routines on the Cadalyst CAD Tips site.
Edited by Kent Cooper - 26.Oct.2016 at 16:32 |
Vladimir Michl
Posted: 31.Oct.2016 at 14:18 |
Unfortunately AddLen is supported in AutoCAD only.
Vladimir Michl (moderator)
Kent Cooper
Posted: 31.Oct.2016 at 17:41 |
Post Reply | |
Tweet
This page was generated in 0,416 seconds.
