Discussion forum
CAD discussion |
Coordinate Extraction |
Post Reply | Page 12> |
Author | |
basusumana
Newbie Joined: 11.Mar.2020 Location: United Kingdom Using: AutoCad LT2020 Status: Offline Points: 13 |
Topic: Coordinate Extraction Posted: 11.Mar.2020 at 12:59 |
Hi,
I have AutoCad LT 2020 version. I have have just bought LT extension and installed it in my system. I want to extract coordinates of the objects from one of my layer. Is there any way by which I can extract coordinates using LT extension? Thank you, Sumana |
Sumana Basu
Geophysicist Brimstone Site Investigation |
Vladimir Michl
Posted: 11.Mar.2020 at 13:04 |
Yes, you can use the function "Report coordinates" in the Tools/Utilities section.
Edited by Vladimir Michl - 11.Mar.2020 at 13:14 |
Vladimir Michl (moderator)
basusumana
Posted: 11.Mar.2020 at 13:09 |
Hi Vladimir,
Thank you for the prompt reply. Could you please let me know which button is report coordinates? I can find 'report lengths' but there is no 'report coordinate' in the LT extension menu bar. Thank you, Sumana
Sumana Basu
Vladimir Michl
Posted: 11.Mar.2020 at 13:13 |
I don't know if you are using the toolbar or ribbon menu but this is the proper ribbon button:
the objects must be either POINT, SHAPE, INSERT, or PLINE
Edited by Vladimir Michl - 11.Mar.2020 at 13:17 |
basusumana
Posted: 11.Mar.2020 at 13:39 |
Hi Vladimir,
Thank you . Got it. But I am still facing problem. The coordinates being extracted are all zero. Thank you, Sumana |
Sumana Basu
Vladimir Michl
Posted: 11.Mar.2020 at 13:56 |
What type of objects are you selecting? Is the drawing metric or imperial?
basusumana
Posted: 11.Mar.2020 at 13:59 |
The coordinates are in mm.
Sumana Basu
Vladimir Michl
Posted: 11.Mar.2020 at 14:02 |
That is strange. I have retested it now in LT 2020, with block references (INSERTs) and it exports their ref.points coordinates properly.
basusumana
Posted: 11.Mar.2020 at 14:03 |
Objects are circles drawn in a layer. I need to extract the coordinate at the centre point of each circles.
Sumana Basu
basusumana
Posted: 11.Mar.2020 at 14:12 |
I have attached one of the dwg file from which I was trying to extract corordinate.
Please have a look. Thank you, Sumana
Sumana Basu
Tweet
This page was generated in 0,371 seconds.
