Discussion forum
CAD discussion |
GEOREFIMG JP2 |
Post Reply |
Author | |
fyserathiuk
Newbie Joined: 10.Sep.2021 Location: New Zealand Using: AutoCAD2018 Status: Offline Points: 3 |
Topic: GEOREFIMG JP2 Posted: 10.Sep.2021 at 02:27 |
Hi Guys I'm having issues to import .JP2 images to AutoCAD using the GEOREFIMG. I'm using .J2W as a world file. When I import a couple of pictures, around 10, using the IMAGESATTACH, the images is imported, but when I run the command GEOREFIMG nothing happens. If I use just one image works, but more than one, no. I did some tests with .PNG/.PGW and .TIFF/.TFW and both worked. Can someone help me? Thanks in advance
Vladimir Michl
Posted: 10.Sep.2021 at 07:56 |
Thanks for reporting this. JP2 images were mistakenly looking for JGW world files instead of J2W. It is fixed now in the V3.3 of the GeoRefImg application (see the Download section).
Vladimir Michl (moderator)
fyserathiuk
Posted: 12.Sep.2021 at 23:58 |
Hi Vladmir, I have tested v3.3 and still not working. I add two JP2 with correlatives J2W to check. Thanks!
Edited by fyserathiuk - 13.Sep.2021 at 00:10 |
Post Reply | |
Tweet
This page was generated in 0,299 seconds.
