Discussion forum
CAD discussion |
Change units of ContourAutoLabel2 |
Post Reply |
Author | |
pixel8er
Newbie Joined: 12.Jan.2015 Location: Australia Using: AutoCAD Status: Offline Points: 6 |
Topic: Change units of ContourAutoLabel2 Posted: 15.Apr.2022 at 05:52 |
Good morning,
Is it possible to edit this block https://www.cadforum.cz/catalog_en/block.asp?blk=5224 so that a conversion factor of 0.001 is applied?
I have tried, but the conversion factor option is greyed out. I work in millimetres but want the contour label to read in metres. Thanks in advance for any suggestions Paul |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Posted: 15.Apr.2022 at 10:57 |
Here is the version with the applied conversion factor:
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
pixel8er
Posted: 16.Apr.2022 at 03:56 |
Thanks so much Vladimir!
Out of interest, how did you add the conversion factor code to the field expression? %<\AcObjProp.16.2 Object(?BlockRefId,1).InsertionPoint \f "%lu2%pt4%pr2%zs8%ct8[0.001]">% Thanks again Paul
Vladimir Michl
Posted: 16.Apr.2022 at 07:32 |
In some cases, you cannot select the codes interactively, by clicking in the Field dialog. But you can always edit the field code manually and paste it into the appropriate place - in the MText text, or in the Attribute dialog as in this case.
pixel8er
Posted: 16.Apr.2022 at 09:10 |
That is so good!
I didn't realise that you could paste the field code directly into the attribute dialogue field. Thanks again Vladimir.
Post Reply | |
Tweet
This page was generated in 0,438 seconds.
