Discussion forum
CAD discussion |
Text from Excel to autocad |
Post Reply |
Author | |
Shamaoon
Newbie Joined: 22.Aug.2023 Location: Pakistan Using: AutoCAD2021 Status: Offline Points: 3 |
Post Options
Thanks(0)
Posted: 22.Aug.2023 at 09:21 |
Recently I have been facing an issue to input text that is in excel spreadsheet into autocad as text, and I have to repeatedly move excel to autocad and autocad to excel to copy paste text. I have seen somewhere that Concatenate in excel with coordinates could create text which i have tried but found no success, kindly share any possible solution to this.
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Post Options
Thanks(0)
You can "concat" text command (in Excel) which will simulate keyboard entry string in AutoCAD. If you create an exactly same string as you would type manually, you can than copy/paste it from Excel to AutoCAD (or save it to a .SCR file and run it with the SCRIPT command).
E.g. _-MTEXT 0,0 _wi 110.0 Hello world _empty_line_ |
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
Shamaoon
Post Options
Thanks(0)
Yes you are right this works but it not useful if i want to change text style ,width factor and to justify as centered, If you think this can be possible kindly share.
Post Reply | |
Tweet
This page was generated in 0,643 seconds.
