Discussion forum
CAD discussion |
DIM RADIUS Center Mark Not Showing |
Post Reply |
Author | |
CADTechie99
Newbie Joined: 09.Nov.2023 Location: United States Using: AUTOCAD 2023 Status: Offline Points: 3 |
Post Options
Thanks(0)
Posted: 09.Nov.2023 at 17:39 |
Hello,
I have adjusted the center mark and its size for radius dimensions in dim style. Nothing changes the mark from displaying as a dot. Inside the dim style dialogue box, the preview correctly shows the center mark. Thank you for the replies.
CADTechie99
Post Options
Thanks(0)
I figured out that the center mark will only display when the leader and text is placed outside an arc and not inside it. The only way I found to fix this is to add my own centermark. Is there a setting to have the dim radius center mark show when placing the text and leader line inside an arc?
Post Reply | |
Tweet
This page was generated in 0,512 seconds.
