Discussion forum
CAD discussion |
How to Create Text with Color Background? |
Post Reply |
Author | |
dery
Senior Member Joined: 31.Jan.2018 Location: United States Using: AutoCAD 2014 Status: Offline Points: 114 |
Post Options
Thanks(0)
Posted: 03.Dec.2023 at 13:17 |
OK, now it works.
The order is: 1. Create a rectangle with the desired size/dimension. 2. Apply hatch (solid) inside the rectangle. 3. Change the color of the hatch to the desired color. 4. Create text inside the hatched rectangle. 5. Change the color of the text to white. 6. Done. Thanks for the help. Edited by dery - 03.Dec.2023 at 16:16 |
Vladimir Michl
Moderator Group Arkance Systems CZ Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2018 |
Post Options
Thanks(0)
Done using the same workflow you described (point order: 1,3,2):
Do not apply any "masks" to the Text/Mtext if you create the rectangular geometry by yourself. Or use the Mask option for the text and set the mask color to purple (e.g. in the Properties, Ctrl+1) but don't create the rectangle/hatch manually.
Edited by Vladimir Michl - 03.Dec.2023 at 09:32 |
Vladimir Michl (moderator)
Arkance Systems - arkance-systems.cz - Autodesk reseller |
dery
Post Options
Thanks(0)
How do you change the color of the text to white?
This is what I've done: 1. Make a rectangle 2. Make the text inside the rectangle. 3. Apply hatch (solid) inside the rectangle. And this is the result: How to make the white background like above pic to same color as the purple background?
Edited by dery - 03.Dec.2023 at 07:14 |
Vladimir Michl
Post Options
Thanks(0)
Just make your text color "white" or "light gray" and put some color geometry "under" it, either literally "under" (using Z-coordinate) or with DrawOrder - e.g. a solid hatched rectangle, 2D shape, wipeout mask or similar.
dery
Post Options
Thanks(0)
Can someone tell me please how to create a white text with color background like pic below in AutoCAD 2014?
Post Reply | |
Tweet
This page was generated in 0,504 seconds.
