Discussion forum
CAD discussion |
How to Create White Text with Color Background? |
Post Reply |
Author | |
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 632 |
Post Options
Thanks(0)
Posted: 04.Dec.2023 at 21:27 |
Don't use a background on the Text?
If you want the Text to be white, use color 255.
dery
Senior Member Joined: 31.Jan.2018 Location: United States Using: AutoCAD 2014 Status: Offline Points: 114 |
Post Options
Thanks(0)
How do you change the color of the text to white?
This is what I've done: 1. Make a rectangle 2. Make the text inside the rectangle. 3. Apply hatch (solid) inside the rectangle. And this is the result: How to make the white background like above pic to same color as the purple background? Edited by dery - 03.Dec.2023 at 07:14 |
vietduc147258
Newbie Joined: 02.Apr.2022 Location: Vietnam Using: Autocad2007 Status: Offline Points: 1 |
Post Options
Thanks(0)
way 1: Select text -> Ctrl+1 -> Find "Background mask" -> Check " Use Background mask" and chose cloclor in "Fill"
way 2: http://www.lee-mac.com/mask.html
dery
Post Options
Thanks(0)
Can someone tell me please how to create white text with color background like image below?
Thanks |
Post Reply | |
Tweet
This page was generated in 0,574 seconds.
