Discussion forum
CAD discussion |
Data Extraction - Ignore overlapping |
Post Reply |
Author | |
wim_wdh
Newbie Joined: 14.Dec.2023 Location: Belgium Using: autocad 2023 Status: Offline Points: 1 |
Post Options
Thanks(0)
Posted: 14.Dec.2023 at 08:09 |
Hello, i would compose the blocks, that would have this problem, into two blocks; one is the fence and the other would be the post. after the drawing is finisched, you explode the combined blocks. after exploding, a simple vba routine can detect if similar blocks have the same insertion points. the vba code can deletes these double insertions. and then you have a correct count
ameco playgrounds - creating, construction and installing indoor playgrounds european market
similac95
Newbie Joined: 15.Aug.2011 Location: United States Using: autocad 2012, inventor2012 Status: Offline Points: 2 |
Post Options
Thanks(0)
Wondering if anyone knows a way to do a data extraction but have it not count overlapping blocks.
Example would be 2 sections of fence but each section is a dynamic block each with a post on both ends. So when you put them together it should be 3 posts but counts 4 since there are 2 in the middle. Is there a way to only count that as 1? Appreciate the help
Post Reply | |
Tweet
This page was generated in 0,384 seconds.
