Discussion forum
CAD discussion |
How to Draw Arc with Known 3 Parameters? |
Post Reply |
Author | |
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1428 |
Post Options
Thanks(0)
Posted: 31.Jan.2024 at 17:41 |
Dery, the "step by step" method is in the CAD/BIM Block library.
dery
Senior Member Joined: 31.Jan.2018 Location: United States Using: AutoCAD 2014 Status: Offline Points: 114 |
Post Options
Thanks(0)
Hi Mr. Joseph, currently I am at this step (please see attached image). Can you tell me please what should I do for the next step? Thank you so much.
dery
Post Options
Thanks(0)
Hi Mr. Joseph. I saw your drawing already. However I still don't understand. How do you obtain those angles? Please advance and explain.
philippe JOSEPH
Post Options
Thanks(0)
It's in the CAD/BIM BLocks : HOW TO DRAW AN ARC-PJH-2014.dwg
dery
Post Options
Thanks(0)
Hi Mr. Joseph, can you create the CAD/BIM block that can be opened in AutoCAD 2014 please? Thanks
Edited by dery - 31.Jan.2024 at 09:37 |
philippe JOSEPH
Post Options
Thanks(0)
Hello Kent and Dery, I have placed in the CAD/BIM Blocks library my file :
HOW TO DRAW AN ARC-PJH.dwg. I see only one arc but I can be wrong.
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 632 |
Post Options
Thanks(0)
... bearing in mind that there are two such Circles, and two resulting Arcs tangent to the red line through point A [unless point A is close enough to an end of the line that one of the tangency points would be off the end].
philippe JOSEPH
Post Options
Thanks(0)
How to draw an arc with three known parameters ?
-1- Offset the red line by 400 on the lower side. -2- Draw a circle of radius 400 centered on the point "A". -3- Draw a circle of radius 400 passing by the intersection between the offseted red line and the circle centered on the point "A". -4- Trim the circle on the red line and the green line and you have got your arc.
dery
Post Options
Thanks(0)
Hi Mr. Philippe Joseph, can you answer my question please?
dery
Post Options
Thanks(0)
I would like to ask technical drawing question.
How do you draw arc with radius of 400 that pass through point A and tangent to the Red line as shown in attached image? Please show me the step-by-step and its construction geometry. Thank you in advance Edited by dery - 29.Jan.2024 at 01:20 |
Post Reply | |
Tweet
This page was generated in 0,398 seconds.
