Discussion forum
CAD discussion |
Miter corners for Polylines with Global Width |
Post Reply |
Author | |
jooogyerek
Newbie Joined: 13.Dec.2014 Location: Slovakia Using: AutoCAD 2012 SV Status: Offline Points: 11 |
Post Options
Thanks(0)
Posted: 19.Feb.2024 at 13:34 |
Applying/setting up Miter corners for non-continuous/complex Linetype Polylines with Global Width
Kent Cooper
Senior Member Joined: 12.Mar.2013 Location: United States Using: AutoCAD2020, 2023 Status: Offline Points: 632 |
Post Options
Thanks(0)
FILLET with zero radius? CHAMFER with zero distances? Or maybe by "miter corners" do you mean what CHAMFER does with non-zero distances? If those are not what you mean, can you post an image showing what you do mean? And is it something that appears different in PLOTting than in drawing on-screen [see "Line join style" options in the Plot Style Table Editor]?
Edited by Kent Cooper - 22.Feb.2024 at 15:49 |
Kent Cooper
Post Options
Thanks(0)
(I can't edit my previous Reply any more, so....) I'm particularly curious about what the non-continuous-linetype and global-width aspects have to do with the question, which is one reason why an image would be helpful. What are you getting, and by what means, and what do you intend [even if you have to "fake it" for illustration]?
Post Reply | |
Tweet
This page was generated in 0,422 seconds.
