CZ | EN | DE
Login or
registration
  Visitors: 6426
RSS discussions
Discussion Discussion forum
HelpCAD discussion
scaling area issue
 Post Reply Post Reply
Author
felipeocampo View Drop Down
Newbie
Newbie
Using: autocad2023
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote felipeocampo Quote  Post ReplyReply Direct Link To This Post Topic: scaling area issue
    Posted: 26.Feb.2024 at 15:10
I have a closed polyline of 653.5977379 m2 area that I want to scale so that it is exactly 653.63 m2, with command SCALE . I can't do it! . I tried using scale factor x 1.00004936 and it doesn't work! I am in the decimal system, dwgunits(6) and in 8 the number of decimals.
Back to Top
Cfytr View Drop Down
Groupie
Groupie
Using: AutoCAD2013
Status: Offline
Post Options Post Options   Thanks (1) Thanks(1)   Quote Cfytr Quote  Post ReplyReply Direct Link To This Post Posted: 26.Feb.2024 at 19:13
1/(653.5977379/653.63)^0.5 = 1.00002468009
Back to Top
Ritter View Drop Down
Newbie
Newbie
Using: Autodesk AutoCAD 2024
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ritter Quote  Post ReplyReply Direct Link To This Post Posted: 14.Mar.2024 at 10:41
Hi Cfytr,
You have Terex Demag AC250-1?
LM
Back to Top
Groupie
Groupie
Using: AutoCAD2013
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cfytr Quote  Post ReplyReply Direct Link To This Post Posted: 14.Mar.2024 at 11:06
no, there is only AC 700
Back to Top
Newbie
Newbie
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ritter Quote  Post ReplyReply Direct Link To This Post Posted: 14.Mar.2024 at 15:16
Thanks for the fast reply!
Nice work.
Grove cranes like: GMK5200-1 or/ and GMK5130-2?
Back to Top
Groupie
Groupie
Using: AutoCAD2013
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cfytr Quote  Post ReplyReply Direct Link To This Post Posted: 14.Mar.2024 at 15:49
there is only:
GMK 6300L-1
GMK 5170
GMK 4100
Back to Top
Newbie
Newbie
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ritter Quote  Post ReplyReply Direct Link To This Post Posted: 14.Mar.2024 at 16:10
I have tried to find this 5 cranes for some time now:
- Terex Demag AC 200-1
- Terex Demag AC 250-1
- Grove GMK 5220
- Grove GMK 5200-1
- Grove GMK 5130-2
Seems like is no hope! Any of this will be a great help for me!
Thanks.
Back to Top
Senior Member
Senior Member
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote philippe JOSEPH Quote  Post ReplyReply Direct Link To This Post Posted: 14.Mar.2024 at 16:45
Hello, if you launch a search with 5130 and with 5220 in the CAD/BIM BLocks library you will find two cranes with blocks ( non dynamic ).
In any case and depending on the use that you will make of this, always search the load charts on the internet to go with.
Edited by philippe JOSEPH - 14.Mar.2024 at 18:23
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,305 seconds.
