Discussion forum
CAD discussion |
scaling area issue |
Post Reply |
Author | |
felipeocampo
Newbie Joined: 26.Feb.2024 Location: Argentina Using: autocad2023 Status: Offline Points: 2 |
Post Options
Thanks(0)
Posted: 26.Feb.2024 at 15:10 |
I have a closed polyline of 653.5977379 m2 area that I want to scale so that it is exactly 653.63 m2, with command SCALE . I can't do it! . I tried using scale factor x 1.00004936 and it doesn't work! I am in the decimal system, dwgunits(6) and in 8 the number of decimals.
Cfytr
Groupie Joined: 16.Jun.2016 Location: Russian Federation Using: AutoCAD2013 Status: Offline Points: 20 |
Post Options
Thanks(1)
1/(653.5977379/653.63)^0.5 = 1.00002468009
Ritter
Newbie Joined: 10.Jan.2024 Location: Romania Using: Autodesk AutoCAD 2024 Status: Offline Points: 3 |
Post Options
Thanks(0)
Hi Cfytr,
You have Terex Demag AC250-1?
LM
Cfytr
Post Options
Thanks(0)
no, there is only AC 700
Ritter
Post Options
Thanks(0)
Thanks for the fast reply!
Nice work. Grove cranes like: GMK5200-1 or/ and GMK5130-2? |
Cfytr
Post Options
Thanks(0)
there is only: GMK 6300L-1
GMK 5170 GMK 4100 |
Ritter
Post Options
Thanks(0)
I have tried to find this 5 cranes for some time now:
- Terex Demag AC 200-1 - Terex Demag AC 250-1 - Grove GMK 5220 - Grove GMK 5200-1 - Grove GMK 5130-2 Seems like is no hope! Any of this will be a great help for me! Thanks.
philippe JOSEPH
Senior Member Joined: 14.Mar.2011 Location: France Using: AutoCAD Mechanical 2017 Status: Offline Points: 1428 |
Post Options
Thanks(0)
Hello, if you launch a search with 5130 and with 5220 in the CAD/BIM BLocks library you will find two cranes with blocks ( non dynamic ).
In any case and depending on the use that you will make of this, always search the load charts on the internet to go with.
Edited by philippe JOSEPH - 14.Mar.2024 at 18:23 |
Post Reply | |
Tweet
This page was generated in 0,457 seconds.
