Discussion forum
CAD discussion |
Date and time are not correct |
Post Reply |
Author | |
interscale
Newbie Joined: 23.Apr.2024 Location: Indonesia Using: AutoCAD2023 Status: Offline Points: 1 |
Post Options
Thanks(0)
Posted: 23.Apr.2024 at 13:43 |
Vladimir Michl
Post Options
Thanks(0)
Right click on the header in File Explorer and choose Modification Date instead of Date.
Vladimir Michl (moderator)
Wimm
Newbie Joined: 04.Apr.2024 Location: Nederland Using: 2021 Status: Offline Points: 2 |
Post Options
Thanks(0)
At the moment I have a problem with Autocad 2021 and that is that it does not want to save a drawing with the correct time and date in the explorer. When I open a drawing, for example UA.001 Existing condition of asphalt pavement, via the explorer and make changes to it and save it, the date and time remains the same as before opening! When I save the modified drawing 'via save as', the date and time do not change either! See appendix 01 The bizarre thing is that the changes in the drawing are saved. When I open Autocad and then use the command “open†in this explorer, I see the correct date and time in the drawing when the changes were made and saved. See appendix 02. |
Post Reply | |
Tweet
This page was generated in 0,375 seconds.
