Discussion forum
CAD discussion |
3D |
Post Reply |
Author | |
chupalok
Groupie Joined: 20.Apr.2009 Location: Philippines Using: autocad 2012, 3dmax 2011,cs5 Status: Offline Points: 64 |
Topic: 3D Posted: 21.Apr.2009 at 16:19 |
HELLO HOW TO CREATE POLYFACE?
Arben.Allaraj
Senior Member Joined: 14.Nov.2007 Location: Albania Using: AutoCAD 2008 Status: Offline Points: 602 |
Posted: 21.Apr.2009 at 21:36 |
Ok see about it in AutoCAD help. |
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com |
chupalok
Posted: 22.Apr.2009 at 04:43 |
thank you very much!!!!! for reply me....
Vladimir Michl
Posted: 22.Apr.2009 at 09:44 |
The Help would give you more information - but generally: the
PFACE command is meant to be used mainly in add-on applications, not interactively.
Ypu have to first define (pick) a series of 3D points and then define the faces by entering point numbers of the face vertices. Not very user-friendly...
Vladimir Michl (moderator)
chupalok
Posted: 23.Apr.2009 at 10:05 |
what kind add on that i use sir?
Vladimir Michl
Posted: 23.Apr.2009 at 14:10 |
You can write or purchase add-on applications (C++, LISP, .NET) which can call internal AutoCAD commands. There are thousands of such applications.
chupalok
Posted: 24.Apr.2009 at 03:05 |
good day sir?
c++,lisp,.net akind of programming language but i dnt know it is a add on application in autocad pls more specify sir? is there a add on software to create pface command like youre what you made it in cad blocks. you know sir you such a amazing to create an automobile in application. i inspire you.
thank you......
Post Reply | |
Tweet
This page was generated in 0,338 seconds.
