Discussion forum
CAD discussion |
LookupXLS - no ask to use previous setting |
Post Reply |
Author | |
jecasas
Newbie Joined: 22.May.2023 Location: Spain Using: Autocad2023, Autocad LT 2024 Status: Offline Points: 2 |
Post Options
Thanks(0)
Posted: 09.Jun.2023 at 08:20 |
Morning, everybody!
I call LookupXLS in a batch process for several drawings in which, after opening each one, I call a SCR file from wich LookupSCR is called as many times as attributes I have to change in that drawing. This looks like the first time I call it in a drawing: FILEDIA 0 LookupXLS "Path" ... And this is the second and following times: FILEDIA 0 LookupXLS N "Path" ... I would like to use always the same .scr but, to achieve that, I would need to call LookupXLS in a way that it will not ask for the use or not of previous settings. Is it possible?
Vladimir Michl
Post Options
Thanks(0)
Yes, it is possible - the version 1.2 now checks if a Script is running and if so, it assumes the first prompt is auto-answered as "No".
Vladimir Michl (moderator)
Post Reply | |
Tweet
This page was generated in 0,351 seconds.
