Discussion forum
CAD discussion |
2d to 3d |
Post Reply |
Author | |
Stevie boy
Newbie Joined: 01.Nov.2011 Location: Thailand Using: AutoCAD2007 Status: Offline Points: 2 |
Topic: 2d to 3d Posted: 01.Nov.2011 at 11:12 |
Hi!
Can anybody advise me what is the process on creating 3d images on 3ds max. Is it possible to transfer 2d (AutoCAD) floor plans into 3ds max, and then from that point continue to create the render? I am new to this area, so any feedback will be greatly appreciated. Thanks in advance! |
John Connor
Senior Member Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 01.Nov.2011 at 11:58 |
I don't think you can render a 2D object. I think it has to be a 3D surface, solid or mesh is order for you to render it since materials/textures would have to be applied.
Maybe you should try your hand at a few basic tutorials first. Wouldn't that be the best way to begin learning how to use the program? Edited by John Connor - 01.Nov.2011 at 12:09 |
<<AutoCAD 2015>> |
Cad64
Senior Member Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 02.Nov.2011 at 06:15 |
You can import your Autocad 2D floorplan into Studio Max and then use that linework to build your 3D model. Here's a good tutorial to help get you started: http://www.3dlessons.com/tutorials/Importing-DWG-s-to-3dsmax-for-Architectual-Visualisation-92037.html
Online Portfolio: http://www.rdeweese.com/
Stevie boy
Posted: 02.Nov.2011 at 06:56 |
Thank you very much, that is great!
KarlMann
Newbie Joined: 27.Jun.2012 Location: Angola Using: fgdfgf Status: Offline Points: 2 |
Posted: 28.Jun.2012 at 10:57 |
recommend you pretty little liars season 2 dvd boxset,a very good-looking DVD!
Post Reply | |
Tweet
This page was generated in 0,305 seconds.
