  Visitors: 4374
CAD tip CAD tip # 12663:
How to transfer my project from Infraworks to Revit?
A - answer If you transfer just the bridge models, use the direct specialized function in Infraworks to convert them to Revit.
For other object types use the DWG file format. But you will need first to pre-convert the model to the FBX or IMX formats. In Infraworks, use the FBX export on the tab Present/Share, import the FBX file into 3ds Max and save it as a DWG file. Alternatively, publish the IMX file for Civil 3D and again - save it in Civil as a DWG for AutoCAD. Then import the 3D DWG into Revit.
Yet other ways are recommended in the tool Convert CAD formats.
IWRevitCivil
7.7.2020    23457×
Prices - CAD eShop:
applies to: Infraworks · Revit · Civil 3D ·
Tip 12779:How to export a hi-res image from Autodesk Infraworks?
Tip 12348:Is it possible to import SketchUp SKP files 2013, 2018,2019 or 2020 into Revit?
Tip 10923:Which Autodesk products do support the IFC format?
Tip 9698:Data formats supported in Autodesk InfraWorks 360.
Tip 8218:Data formats supported in Autodesk Infrastructure Modeler 2012.
