CAD tip # 13963:
applies to: Inventor · |
Tip 13965: | Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic) |
Tip 13040: | iLogic - display information about complexity of an Inventor part. |
Tip 12392: | Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA |
Tip 11211: | Mass change of units in the whole Inventor assembly. |
Tip 9952: | iLogic rule - check whether iProperties are overridden. |
Swept surface is not displayed in my Inventor model.
Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic) « | » Fermat's spiral in AutoCAD.
