New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 11693:
Question
A simple LISP utility AddMe adds numbers from all selected texts (text/mtext) in your AutoCAD DWG drawing. The resulting sum is returned on the command line.
You can download AddMe from Download, load it with APPLOAD and start by typing the AddMe command. Select the texts containing integers or decimal real numbers. AddMe lists the value of their sum. Non-numeric texts will be ignored.
For a more complex, interactive usage see GrSelNum - Tip 11492
ACAD
22.11.2017    13303×
applies to: AutoCAD ·
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 14361:Extended ATTOUT/ATTIN for block attribute management in Excel (also for LT).
Tip 14285:How to identify duplicate blocks in AutoCAD DWG drawings? SelDupBlk.
Tip 14280:How to add elevation value (Z-coordinate) to texts with point numbers?
Tip 14202:Recurring "Duplicate Sheet Name" dialogs.
Back    All CAD Tips
Categ:
