New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 9996:
Question
The error message VVC: internal error displayed when running a LISP application in AutoCAD 2015 relates to the changes in the "fibers" technology.
To fix it, edit your AutoLISP/VisualLISP add-on application (.lsp) and replace the function (command) with the newer (command-s). Should this problem appear in any of the freeware LISP applications by CAD Studio, please let us know on info@cadstudio.cz.
ACAD2015
8.9.2014    12861×
applies to: AutoCAD 2015 ·
Tip 14484:Minimum, maximum, average, sum and delta values from selected drawing texts.
Tip 14481:How to bulk publish a folder of DWG/DXF files to PDF?
Tip 14477:PurgeAll - automation of DWG file cleaning
Tip 14461:How to convert multiline geometry to a standard polyline?
Tip 14457:What is the difference between the commands GEOGRAPHICLOCATION, MAPCSASSIGN and GEOCSASSIGN in Map/Civil 3D?
Back    All CAD Tips
Categ:
