CAD tip # 9276:
applies to: AutoCAD · AutoCAD LT · AutoCAD Architecture · Civil 3D · AutoCAD Mechanical · AutoCAD Map 3D · DWG · |
Tip 13868: | XrefStamp - create a dynamic list of xrefs in your DWG drawing. |
Tip 11376: | Attaching a xref to AutoCAD DWG sets a relative path automatically, can I change it to absolute? |
Tip 10394: | Attach xrefs from a predefined folder (path). |
Tip 7549: | DEPENDS - displaying file dependencies in a DWG drawing. |
Tip 7016: | Mount disks as Windows folders. |
Network version of AutoCAD displays the error 0.0.0
Import STEP - Failed to calculate silhouettes of a face. « | » RENAME on steroids - complex renaming of AutoCAD objects (blocks, layers...)
