New CADforum look launched.
Over 1.081.000 registered users (EN+CZ). New 1D nesting and 3D nesting tools, updated Color converter. New AutoCAD 2025 commands and variables. Learn about twiGIS.
CAD tip # 7412:
Question
AutoCAD 2011, Inventor 2011 and other CAD applications of the 2011 family share a common library of rendering materials.
Due to the shared nature of these libraries, they are not uninstalled automatically when uninstalling one of the 2011-products (the would be missing in the other products). It is neccessary to uninstall them separately - before you uninstall the CAD product.
The installation of the 2011-family products contains 3 different material libraries. They differ in the size (precision, granularity) of their texture bitmap images:
- Autodesk Material Library 2011 (CM)
resolution: cca 256x256 pixels, size: 176MB, required for AutoCAD, Inventor and Revit (Protein UI) - Autodesk Material Library 2011 Base Image Library (ILL)
resolution: cca 512x512 pixels, size: 255MB - Autodesk Material Library 2011 Medium Image Library (ILM)
resolution: cca 1024x1024 pixels, size: 608MB
If you need to reinstall the libraries, you can do this from the product installation media - again in the order from the smallest to the largest one. You can find the installation archives in the following folders:
- \support\ADSKMaterials\CM\ProteinMaterials.msi
(Autodesk Material Library 2011, CM) - \support\ADSKMaterials\ILL\BaseImageLibrary.msi
(Autodesk Material Library 2011 Base Image Library, ILL) - \support\ADSKMaterials\ILM\MediumImageLibrary.msi
(Autodesk Material Library 2011 Medium Image Library, ILM)
ACAD2011Civil2011ADT2011Inv2011Revit2011
*CAD
21.6.2010
22232×
