New CADforum look launched.
Over 1.090.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip # 6724:
Question
With the CADstudio BLegend utility you can easily create a legend (BOM table) of blocks used in your drawing (including icons - thumbnail previews of the blocks).
Load the LISP utility with APPLOAD and start it with the BLegend command. Since version 1.1 you can select block names and layers to include in the resulting table. Since version 1.2 you can schedule selected block references only. Then pick the top left corner of the legend table and specify its width. The legend will list all blocks in the current space (model/paper), their names, descriptions (see the block editor) and count. The legend is created in the current table style. You can then customize it (e.g. remove a column).
The labels are created in the current locale language (CZ/EN).
Legend (in Czech) created from the DWG block library Animals
You can download the free BLegend utility from Download.
ACAD2016ACAD2010ACAD2008ACAD2007ADTMapCivil
4.6.2009
42819×
applies to: AutoCAD 2016 · AutoCAD 2010 · AutoCAD 2008 · AutoCAD 2007 · AutoCAD Architecture · AutoCAD Map 3D · Civil 3D ·
