CAD tip # 8052:
Question
To break selected polylines at multiple points - at the POINT objects placed along the polylines - you can use the LISP utility CADstudio BreakPls.
This tool prompts to select the polylines and then automatically breaks them. The points must be visible (PDMODE). An example of the original polylines and the status after BreakPls is illustrated on the following pictures:
Original drawing
After BreakPls - only some segments selected
The BreakPls utility can be downloaded from
Download
ACADADTCivilMap
21.6.2011
19946×
