  Visitors: 5505
CAD tip CAD tip # 13435:
Bulk setting of layer properties according to the object in that layer.
A - answer If you receive an AutoCAD DWG drawing containing all its layers set to "Color: White, LineType: Continuous, Thickness: ByLayer", and the objects in the layers are individually colored to some common color and linetype, you can use the PropByObject tool to set the properties of the layers according to the properties of the first object in the specific layer. You can then return the properties of those objects to "SetByLayer".
The PropByObject command is a part of the PropByLayer utility - see Download. Once loaded (APPLOAD), you can run it by typing the command name.
The command prompts you to select a list of layers:
Process layers [All/Except 0/noXrefs/White/Names]
i.e.: all, all except layer 0, all except xrefs, white/unconfigured layers only, or a list or mask of layer names to process.
The properties color (including truecolor), line type, and line thickness are transferred.
ACADADTACADMPlantMapCivil3D
16.8.2022    23398×
Tip 14033:Clipping blocks, images, curves, xrefs - everything, into any shape
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13878:SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions
Tip 13858:Is there also a SETBYBLOCK command?
Tip 13550:Text with automatic label of the layer it lies in.
