  Visitors: 7116
CAD tip CAD tip # 12555:
Can I upgrade my CAD/PDM server to Windows Server 2019?
A - answer Typical components installed on servers in a CAD environment are:
  • License manager - AdLM
  • Vault Server
So before you upgrade to a new server OS, make sure first, that your versions of these components are compatible with Microsoft Windows Server 2019.
The Autodesk Network License Manager (AdLM) in the version for the "2021" product family, ie. version 11.16.2.0, is compatible with Windows Server 2019 - see Tip 8604. But its older version are not compatible. So first update your AdLM to the new version - see Download.
The Autodesk Vault Server (ADMS) in the version 2021 is compatible with Windows Server 2019. Older Vault versions are not. See Vault - system requirements.
[compatibility]
ACADInvRevitCivilMaxVault2021
100% Win  CAD
31.3.2020    10327×
applies to: AutoCAD · Inventor · Revit · Civil 3D · 3ds Max · Vault 2021 ·
Tip 13633:How to run Revit, Inventor or Windows version of AutoCAD on macOS?
Tip 10342:Compatibility of Vault Server with older versions of Vault clients.
Tip 8610:Compatibility of Vault server 2013 with older client versions.
Tip 7536:How to convert a STL file back to AutoCAD or Inventor?
Tip 7407:Vault 2011 error - older version of SQL Server.
