CAD tip # 13578:
applies to: AutoCAD · AutoCAD Architecture · AutoCAD Plant 3D · AutoCAD Mechanical · Civil 3D · AutoCAD Map 3D · |
Tip 11289: | Adding, multiplying and rounding numbers inside DWG drawing texts - NumInText. |
Tip 10761: | Dynamic block attributes do not respect visibility states. |
Tip 6381: | Arithmetic functions in AutoCAD fields. |
Tip 1451: | How to mirror a block with text when text should remain readable? |
