  Visitors: 7433
CAD tip CAD tip # 10137:
Changed behavior of the Edit text command in AutoCAD 2015.
A - answer Autodesk has changed the behavior of the default text editing command in AutoCAD 2015.
In previous versions, it was possible to edit one text and immediately go to editing of another text (next selected). This is no more possible in AutoCAD 2015. After you edit one text object, the command terminates.
This changed behavior is caused by differences between the old command DDEDIT and the newly used command TEXTEDIT. You can avoid this quite simply. In the CUI dialog box, change the command macro for the option „Double click actions“ > „Text“ > „Text Edit“. Write the following command to the field „Macro“ on the right-hand side:
^C^C_multiple;_textedit
(sans the quotes) instead of the existing:
^C^C_textedit
Since version 2017 you can also use the TEXTEDITMODE variable.
ACAD2017ACAD2015LT2015
15.12.2014    13327×
Prices - CAD eShop:
Tip 14080:AutoCAD 2025 is not displaying some fonts correctly.
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13831:ReplMTcol - recoloring parts of text in paragraph Mtext.
Tip 13802:Dual-color hatches in AutoCAD.
Tip 13788:Green square - mathematical charade and parametric constraints in AutoCAD.
