CAD tip CAD tip # 10482:
Question
So far, only limited number of Autodesk CAD and BIM products is officially supported in Windows 10 and in Windows 7/8.x with .NET Framework 4.6. Versions 2017-2020 (and up) are fully compatible.
  • Inventor 2016 is supported in Win10 operating system
  • AutoCAD 2016 is supported with A2016-family Service Pack 1
  • Plant 3D 2016 is not supported in Win10
  • Revit 2016 is not supported but works in most cases (some graphical issues)
  • Vault 2016 (and earlier) is not supported in Win10
  • Fusion 360 is officially supported in Win10
  • AutoCAD 2015 family is supported in Win10 since SP2 with the Win10 compatibility hotfix (see Download)
  • AutoCAD 2014/2013 won't be officially supported in Win10 OS
The technical problem of incompatibility is usually in the .NET Framework version. Try to temporarily disable the .NET 4.6 in your Windows 10, install .NET 4.5 and then re-enable the version 4.6. The CAD application will be then able to pick the 4.5 version. You can also install the "AutoCAD 2015 .NET Installation Hotfix" (see Download).
More in Autodesk Windows 10 and .NET 4.6 and in the Czech tip
ACADInvCivilRevitmaxSuiteVault
100% Win10CAD
2.9.2015   31812×
this tip shared by ARKANCE experts applies to: ACAD · Inv · Civil · Revit · max · Suite · Vault ·
Tip 15120:Error: Fast shaded mode is not available.
Tip 15116:Compatibility of the AutoCAD 2026 family with .NET 10 (and Inventor, Revit).
Tip 15038:Texts exported from AutoCAD to PDF appear slightly smaller and misaligned.
Tip 14986:How to launch Autodesk Fusion online, in a web browser?
Tip 14902:Which graphics cards are certified for Autodesk Fusion?
Back    All CAD Tips
Categ:
