CAD tip # 9651:
Question
The following video-tip illustrates how to convert a 3D mesh (surface) model (e.g. from a DWG file) to a solid body using Inventor's stitch function. The mesh model is composed from 3DFaces and it has to be watertight - fully enclose a volume. If you generate your surface model algorithmically (e.g. using 3DPlot) or with ReCap functions, try to keep it simple.
When importing your DWG file, make sure you click through the folder structure in the Open dialog - do not just paste the full filename. In the import wizard, check the neccessary options to load the DWG objects to a 3D part file.
The loaded model is a surface model (has e.g. no volume in iProperties). You can stitch it to a solid part (stitching can use a tolerance setting). The solid part can be then re-exported to a DWG or other CAD formats.
Inventor
18.1.2014
30464×
this tip shared by ARKANCE experts applies to: Inventor ·
