New CADforum look launched.
Over 1.085.000 registered users (EN+CZ). Try the new Engineering calculator, the CAD conversion wizard, the Color converter and USD viewer. Learn about twiGIS.
CAD tip CAD tip # 8593:
Question
If you want to disable (suppress) dynamic previews (in-canvas) when changing drawing object properties from the ribbon or Properties palette, switch off the variable PROPERTYPREVIEW.
This variable influences also the switching of visibility states in the block editor (BEDIT).
ACD2013
19.4.2012    5991×
applies to: ACD2013 ·
Tip 10388:How to disable downloads for a selected file in A360 Team?
Tip 9153:Arrowheads or other parts of dimensions are not printed.
Tip 7169:PreSave reactor - automatic operations on drawing save.
Tip 6467:How to disable the pop preview when printing from AutoCAD to PDF?
Tip 3926:Simply add your own tools to a Tool Palette.
Back    All CAD Tips
Categ:
