  Visitors: 5635
CAD tip CAD tip # 8794:
Display CAD model in true size 1:1 on your monitor.
A - answer To get a better idea of ​​the visual appearance of the designed product or to visually combine a CAD model with a real object (e.g. a manufactured component), you may need to display a model or drawing on your monitor in true scale, 1:1, in real dimensions.
For these cases, you can use the add-on utility for AutoCAD - CADstudio View11. It automatically zooms DWG objects in the model space so that they are presented on your screen exactly as large as in the real world (i.e. physically 1:1 in mm). Under normal circumstances, CAD ​​applications display the designed objects in an unspecified scale depending on the size of the monitor, the display resolution and the current zoom level.
You can download the VIEW11 utility from Download, load it with APPLOAD and then run the VIEW11 command. The command prompts (only once in a session) for the monitor diagonal size in inches - e.g. 17, 20, 24 (usually can be deducted from the monitor model number), and for the requested unit scale. To view the model drawn in millimeters, just accept the default scale of 1:1. For models in cm, enter 10 (i.e. 10:1). View11 sets the required zoom and then you see your model in actual millimeters - and you can e.g. measure it with a ruler on the screen. In case of displaying the PC output with a projector (beamer), measure first the diagonal of the projected picture.
Example of applying the command VIEW11 - the status before:
Before
and the status after entering the command:
After VIEW11
Expect some inaccuracies brought by the parallax of the on-screen readouts and by differences between the theoretical and actual monitor diagonal size.
ACADADTACADMCivilMapACADE
31.8.2012    26009×
Tip 13996:Automatic hide for Revit palettes - save screen space (undocumented).
Tip 13965:Total length of sweeps in Inventor - wires, pipes, trusses, tubes, hoses (iLogic)
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13884:How to send e-mails with an iLogic macro?
Tip 13868:XrefStamp - create a dynamic list of xrefs in your DWG drawing.
Automatic nesting of 2D parts on rectangular sheets in AutoCAD
AutoNEST 2008 More info
