CAD tip CAD tip # 7417:
Question
When working in survey maps or in situations with large coordinates, AutoCAD may switch to the "engineering" or "scientific" notation (with the "E" exponent - e.g. -1.23456789E+06) to display coordinates with the specified number of decimal places.
You can suppress this switch either by lowering the number of displayed decimal places (see the UNITS command or the LUPREC variable), or by using the LISP function (rtos).
Instead of the ID command, you can e.g. use the following Lisp routine (save it to fullid.lsp, load it with APPLOAD and run it with the fullID command), which displays large coordinates as a standard decimal number:
;Full ID
;6/2010 - www.cadstudio.cz
(defun C:fullID ( / pt)
 (setq pt (getpoint "\nPick a point to ID: "))
 (if pt
 (prompt (strcat "\nX = "(rtos (car pt) 2)
                  " Y = " (rtos (cadr pt) 2)
                  " Z = " (rtos (caddr pt) 2)))
 (princ)
ACADADTACADMCivilMapTB
22.6.2010   35660×
this tip shared by ARKANCE experts applies to: ACAD · ADT · ACADM · Civil · Map · TB ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14507:Fixed Workpoints (X,Y,Z) in Autodesk Inventor.
Tip 14242:How to find the minimum, maximum or local extreme of a 2D or 3D curve?
Tip 13971:What do geolocation codes like 8FWPXFCF+82 or 33UVQ61402434 mean?
Back    All CAD Tips
Categ:
