CAD tip CAD tip # 7481:
Question
Besides the standard dashed linetypes and complex linetypes using shapes, AutoCAD allows to create custom linetypes using texts. These texts don't need to be neccessarily only letters and numbers - you can also use symbols.
Symbols are contained in most fonts and you can access them through Unicode codes. But you need to use a "rich" font containing the requested symbol. The Truetype font Arial (Arial.ttf) is one of such fonts - and Arial is the default font used in the predefined style "Standard" in newer versions of AutoCAD. So we can avoid referring a specific style in the linetype definition, and first of all avoid creating the specific style in all drawings which should use the newly defined linetype.
Examples of such symbol linetypes are these dotted (spotted) and arrow-type linetypes:
Text/symbol linetypes
The definitions of the displayed linetypes follow (metric units):
*DOTS,Dots .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .
A,.000001,-3,["\U+25CF",Standard,S=3,R=0,X=-1.25,Y=-1.25],-3
*DOTS1,Dots1 .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .  .
A,.000001,-3,["\U+2022",Standard,S=3,R=0,X=-1.44,Y=-1.44],-1.7
*ARROW,Arrow1  >  >  >  >  >  >  >
A,.000001,-3,["\U+25BA",Standard,S=3,R=0,X=-1.35,Y=-1.35],.000001,-4
You can also download it HERE
You can add these definitions to your ACADISO.LIN (or ACAD.LIN) file, or you can save them to a separate LIN file. You can load a .LIN file into an AutoCAD DWG drawing with the LINETYPE command.
The spacing between symbols is controlled by the negative values in the definition. The symbol size is controlled by the linetype scale property. The small dots between symbols are neccessary as the linetype definition must start with a full line segment.
We recommend to use the "Linetype generation" property for polylines (PLINEGEN=1).
ACADACLT
28.7.2010   74539×
this tip shared by ARKANCE experts applies to: ACAD · ACLT ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 15017:AutoCAD Drawing Cleanup Utility - a standalone tool to purge your DWG files.
Tip 14526:How to export geometry from AutoCAD DWGs to JSON files and import it back?
Tip 14509:AutoCAD linetypes - the A/R/U orientation options in complex text-linetypes.
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Back    All CAD Tips
Categ:
