  Visitors: 4444
CAD tip CAD tip # 7151:
Error 2738 while installing Design Review (or other app).
A - answer When you install the Autodesk Design Review (ADR, or another application), the following error message is displayed:
ERROR 2738. COULD NOT ACCESS VBSCRIPT RUN TIME FOR CUSTOM ACTION.
Either you have not enough access rights for the installation or the system component VBScript is not available. Try to re-register the DLL component of the VBscript runtime interpreter - run the command window CMD.EXE as an Administrator and enter the command:
regsvr32.exe c:\windows\system32\vbscript.dll (SysWow64 for 64-bit systems)
If the registration completes successfully, retry the installation of the CAD application.
If the above mentioned process fails, use REGEDIT to delete the following registry keys:
  • HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}
  • HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\{F414C260-6AC0-11CF-B6D1-00AA00BBBB58}
ACADDWG
100% Vista,Win7  CAD
10.1.2010    15268×
Prices - CAD eShop:
applies to: AutoCAD · DWG ·
Tip 14007:Workaround for the missing (vlax-create-object) in AutoCAD LT (voice, clipboard, etc.)
Tip 14006:Universal MsgBox in AutoLISP.
Tip 13583:Evaluate math expressions in AutoCAD DWG texts.
Tip 10955:Evaluate VBScript functions from AutoLISP.
Tip 7739:Empty (white) activation window.
