CAD tip CAD tip # 13784:
Question
AutoCAD LT does not offer the DATAEXTRACTION command, but you can use one of the most common variants of this command - exporting block coordinates - even in AutoCAD LT. At least since version 2024 (and up), which supports LISP applications.
Using a freeware utility by ARKANCE - BlockCoords - you can easily export the coordinates of selected blocks, including their attributes, if any, and dynamic properties (incl. visibility state), from both AutoCAD and AutoCAD LT to a CSV table for Excel.
Download the BlockCoords application from DL Download, load it into your CAD using APPLOAD and type the BLOCKCOORDS command. Select an example of the block you want to export, and then all the references of that block you want to export (e.g. All). The application will create a .CSV file in the current working folder (with the same name as your DWG drawing) with a list of X,Y,Z coordinates and values of all block attributes.
The CSV file uses the correct Excel delimiter and an automatic header - no need to set anything.
Sample output:
X;Y;Z;"NUMBER"
2618.603164;1648.992874;0;"6"
2626.207808;1649.933546;0;"5"
2636.270122;1646.061134;0;"4"
2640.223405;1634.706376;0;"3"
2640.223119;1628.098149;0;"2"
2638.393498;1616.722316;0;"1"
BlockCoords in use:
In V1.1 we have added support for dynamic blocks and showed a mod for export of rotation angles (uncomment the second lines with "***" and comment the first ones).
In older versions of AutoCAD LT you can use the Export XYZ function from our LT Extension for a similar purpose.
See also the similar utility extended ATTOUT.
ACADACLT2024ADTACADM
13.7.2023   68570×
this tip shared by ARKANCE experts applies to: ACAD · AutoCAD LT 2024 · ADT · ACADM ·
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 14894:Importing CSV points in Map/Civil - ImportPoints vs. MapImport.
Tip 14869:How to generate a Regression curve through a set of points in AutoCAD or other CAD?
Tip 14630:Extended ASCPOINT - import coordinates from CSV file, including blocks with attributes, GPS coordinates, etc.
Tip 14304:How to generate a report of used blocks including their visibility status in AutoCAD LT?
Back    All CAD Tips
Categ:
