  Visitors: 4692
CAD tip CAD tip # 12392:
Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
A - answer Using a VBA macro or an iLogic rule you can automate export of an unfolded sheetmetal part from Inventor to a selected version of the DXF format, to your preferred layers and linetypes.
The export process is controlled through the WriteData operation and through its parameters given as arguments of the "FLAT PATTERN DXF" or "FLAT PATTERN DWG" operations. A simple version of such iLogic or VBA macro looks e.g. like this (different parameter types are listed; must be invoked from the unfold environment):
Dim oDataIO As DataIO
Dim oPart As PartDocument
Dim sDXFname As String
Dim csOut As String
oPart = ThisApplication.ActiveDocument
oDataIO = oPart.ComponentDefinition.DataIO
sDXFname = oPart.FullFileName & ".DXF"
'csOut = "FLAT PATTERN DXF?TangentLayer=Tangents&SimplifySplines=True"
'csOut = "FLAT PATTERN DXF?AcadVersion=2000&BendUpLayer=IV_BEND&BendUpLayerLineType=37634&BendUpLayerColor=255;255;0&BendDownLayerLineType=37634"
csOut = "FLAT PATTERN DXF?AcadVersion=R12" _
        + "&OuterProfileLayer=IV_OUTER_PROFILE" _
        + "&InteriorProfilesLayer=IV_INTERIOR_PROFILES" _
        + "&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL"
oDataIO.WriteDataToFile (csOut, sDXFname)
An overview of the individual parameters - all parameters of the type "*Layer" can have also additional parameters with the suffixes LineType, LineWeight, or Color (e.g. TangentLayerLineType, TangentLayerColor):
ParameterTypeDefaultNote
TangentLayer StringIV_TANGENT
OuterProfileLayer StringIV_OUTER_PROFILE
ArcCentersLayer StringIV_ARC_CENTERS
InteriorProfilesLayer StringIV_INTERIOR_PROFILES
BendLayer StringIV_BENDBendUpLayer + BendDownLayer (legacy)
BendUpLayer StringIV_BEND
BendDownLayer StringIV_BEND_DOWN
ToolCenterLayer StringIV_TOOL_CENTERToolCenterUpLayer + ToolCenterDownLayer (legacy)
ToolCenterUpLayer StringIV_TOOL_CENTER
ToolCenterDownLayer StringIV_TOOL_CENTER_DOWN
FeatureProfilesLayer StringIV_FEATURE_PROFILESFeatureProfilesUpLayer + FeatureProfilesDownLayer (legacy)
FeatureProfilesUpLayer StringIV_FEATURE_PROFILES
FeatureProfilesDownLayerStringIV_FEATURE_PROFILES_DOWN
AltRepFrontLayer StringIV_ALTREP_FRONT
AltRepBackLayer StringIV_ALTREP_BACK
UnconsumedSketchesLayer StringIV_UNCONSUMED_SKETCHES
TangentRollLinesLayer StringIV_ROLL_TANGENT
AcadVersion String 2018, 2013, 2010, 2007, 2004, 2000 or R12
CustomizeFilename String
ExportUnconsumedSketchPropertiesBooleanFalseFalse = to the layer UnconsumedSketchesLayer
SimplifySplines BooleanTrueReplace spline with straight segments
SplineTolerance Double0.01Chord length when simplifying splines
AdvancedLegacyExport BooleanTrue
MergeOuterContour BooleanFalselegacy
MergeProfilesIntoPolylineBooleanFalse
RebaseGeometry BooleanFalseMove geometry to the 1st quadrant
TrimCenterlinesAtContourBooleanFalseTrim centerlines at the countour
InvisibleLayers StringList of layers to make invisible, delimited with ";"
An overview of codes for the "...LineType" parameters at the individual layers (see the note in the previous table and see the examples above):
Symbolic name Value (enum code)
kChainLineType 37644
kContinuousLineType 37633
kCustomLineType 37649
kDashDottedLineType 37638
kDashedDoubleDottedLineType 37645
kDashedHiddenLineType 37641
kDashedLineType 37634
kDashedTripleDottedLineType 37647
kDefaultLineType 37648
kDottedLineType 37636
kDoubleDashDoubleDottedLineType 37639
kDoubleDashedChainLineType 37637
kDoubleDashedDottedLineType 37646
kDoubleDashedTripleDottedLineType 37640
kLongDashDottedLineType 37642
kLongDashedDoubleDottedLineType 37635
kLongDashTripleDottedLineType 37643
If you need to create the config string conveniently, through an interactive dialog, you can use the standalone FlatPatternConfigBuilder utility by CAD Studio:
Inventor
7.10.2019    27743×
Prices - CAD eShop:
applies to: Inventor ·
Tip 12416:How to export DXF outline of unfolded sheetmetal in Fusion 360, with no bending lines.
Tip 11720:How to export unfolded sheetmetal parts in Fusion 360?
