New CADforum look launched.
Over 1.089.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip # 6795:
Question
The free AutoCAD utility ARKANCE FieldLink displays temporary lines (arrows) between dynamic text fields and the objects, which properties are used in the fields. You can also select the source objects of these dependencies.
So you can easily represent (visualize) links and relations (connections, dependecies) between text fields (texts, attributes, table cells) and their dependent drawing objects (entities) - e.g. between a boundary polyline and its acreage label. The lines also identify all fields depending on objects. The temporary lines are automatically erased on redraw or zoom operations. Alternatively, you can make them a permanent drawing geometry.
You can download the the FieldLink application from Download. Load it with APPLOAD and start the FIELDLINK command.
ACADADTMapCivilACADMABS
14.7.2009
13646×
applies to: AutoCAD · AutoCAD Architecture · AutoCAD Map 3D · Civil 3D · AutoCAD Mechanical · AutoCAD/Revit MEP ·
