  Visitors: 956
CAD tip CAD tip # 9185:
Fix problem of Areas on self-intersecting curves in AutoCAD 2013.
A - answer The command AREA in AutoCAD 2013 (old, no more referenced from menu) does not report proper area of polylines containing intersecting or overlapping segments (internal loops). Also the Area property is not displayed in the Properties palette for such curves. An example of such outline polyline (an overlapping segment near "+"):
The proper command for displaying area (acreage) - MEASUREGEOM - at least visually warns (green area displayed) when measuring such non-standard outline polylines. On the other hand, the area report command - DATAEXTRACTION - reports proper area of such polylines and the same proper results are listed in the utility for area summaries per layer - CADstudio AddArea and also in the similar "Area report" command in CADstudio LT Extension.
Standard outline polylines without crossovers and overlaps work properly in all cases. Other AutoCAD versions are not affected by this problem.
To fix problematic polylines in AutoCAD 2013 you can use the freeware utility CADstudio FixArea13 - see Download. This tool automatically reverses "suspect" polylines (where area reported with the AREA command and with the Are property differs), and these reverted polylines are then handled properly.
Please mind oriented polylines with uni-directed complex linetypes.
Using two LISP variables you can control the precision of the area comparison and suppress highlighting (disappears after REGEN) in FixArea13:
(setq _fixAreaDiff 0.001)
(setq _fixAreaNoHighlight T)
ACAD2013ADT2013Civil2013LT2013
8.4.2013    35598×
Tip 13163:Blended transitional solid between irregular regions, circle-rectangle transition (3D in AutoCAD)
Tip 12926:How to import point coordinates from Excel to AutoCAD?
Tip 12479:PkLength - export line lenghts to Excel.
Tip 12105:Select the smallest DWG object - MinOf utility.
Tip 11246:Easier hatching between two polylines - Hatch2L.
