CAD tip # 12368:
applies to: AutoCAD · AutoCAD Architecture · AutoCAD Plant 3D · AutoCAD Mechanical · Civil 3D · AutoCAD Map 3D · |
Tip 13887: | ClosestPt - the nearest point on another curve |
Tip 13827: | Snap points to the nearest curve/polyline with Snap2Curve. |
Tip 13333: | "Zero length line" warnings or misplaced vertices when importing vertex coordinates from scripts. |
Tip 13221: | Attractor - snap multiple objects to existing points/vertices. |
Tip 12762: | Multiline and vertical text in Fusion 360 sketches. |
Quick dynamic measuring stopped to work. « | » How to show color print (sketch) also on the sheetmetal flat pattern?
Featuring: DwgTextTranslator translates a series of drawings from one language to another using MS Access. Download a fully functional trial version. |
