CAD tip # 7096:
Tip 7599: | List of new AutoCAD commands from Subscription Advantage Packs. |
Tip 7589: | Import and export IGES files in AutoCAD (DWG). |
Tip 7010: | AutoCAD reports SELECTSIMILAR as an unknown command. |
Tip 6476: | How to downgrade AutoCAD, Inventor or Revit? |
Tip 5536: | Compatibility of Autodesk CAD applications with 64-bit Windows versions. |
Set your Vista 64 to a faster boot.
