CAD tip # 13931:
applies to: Revit · |
Tip 13985: | Advanced pressure drop calculations in Revit (multiple connections). |
Tip 9246: | Pipe label in Revit MEP - outer diameter x wall thickness |
How to import a PDF file into AutoCAD?
