  Visitors: 8035
CAD tip CAD tip # 9879:
How to change e-mail address in your "Autodesk ID" account?
A - answer If you need to change the e-mail address connected with your personal account "Autodesk ID" used to access Autodesk web/cloud services, edit it in your profile.
Log in to accounts.autodesk.com with your login name and password and go to the PROFILE tab. In the upper section "Profile", click on "Edit profile" and change the e-mail address used for communication with your collegues and other users of web services you are logging in with your Autodesk ID. Save the changes.
Then in the bottom section "Account Info", use the the "Edit Account" link and set your new changed e-mail address - this contact will be used for internal communication between Autodesk and you (e.g. for Subscription). Both addresses can differ. If you entered no address in your profile (upper), will your account address (botttom) be used as a backup contact also for communication with other users, for sharing documents, notifications, etc. Again, save the changes.
Autodesk360cloud
20.6.2014    9165×
Prices - CAD eShop:
applies to: Autodesk360 · cloud ·
Tip 14053:Why doesn't my export from Civil 3D to IFC 4.3 export surfaces and solids?
Tip 13917:Check for concurrently running named licenses (device limit).
Tip 13539:Revit 2023.1 shows "Twinmotion is not installed"
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 13216:Internal CAM kernel error in Fusion 360.
VRMLout More info
