If you need to check in your LISP application whether a specific Windows application or process (items you can see in the Task Manager) is running, you can use the following LISP function:
(defun isRunning? (procname / apps item lst meth1 meth2 WMI)
(setq WMI (vlax-create-object "WbemScripting.SWbemLocator")
meth1 (vlax-invoke WMI 'ConnectServer nil nil nil nil nil nil nil nil)
meth2 (vlax-invoke meth1 'ExecQuery "Select * from Win32_Process"))
(vlax-for item meth2
(setq lst (append lst (list (vlax-get item 'CommandLine))))
(vlax-release-object WMI)
(vlax-release-object meth1)
(vlax-release-object meth2)
(setq lst (vl-remove nil lst))
(vl-some '(lambda (s) (wcmatch (strcase s) (strcat "*" (strcase procname) "*"))) lst)
For the procname parameter, use any substring identifying the runstring of the specific application or process - e.g. the parameter "acad.exe" should always return T, as AutoCAD is running for sure:
(isRunning? "acad.exe")
Is the Windows indexing process running?
(isRunning? "SearchProtocolHost")
