Over 1.127.000 registered users (EN+CZ).
CAD tip # 9097:
Question
You can use the SURFPATCH command to convert a closed 3D polyline to a surface patch (3D surface).
The command option _Curves and selection of the boundary control curve will create a patch surface associative to this curve. With its properties you can set the density of displayed isolines and control other parameters of the boundary patch.
ACADACAD2012ACAD2011
17.2.2013
95082×
