CAD tip CAD tip # 8201:
Question
The TXT2MTXT command can be used to convert multiple texts to a single Mtext. But if you need to just convert the type of multiple drawing objects from Text to MText - without combining them - you can use the following simple AutoLISP code.
Save it to txt1mtxt.lsp, load it with APPLOAD and start the TXT1MTXT command:
; CADstudio TXT1MTXT - text to mtext (individual)
(defun c:txt1mtxt (/ ss lst x)
  (setvar "CMDECHO" 0)
  (command "_undo" "_begin")
  (setq ss (ssget '((0 . "TEXT"))))
  (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
  (mapcar '(lambda (x) (command "txt2mtxt" x "")) lst)
  (command "_undo" "_end")
  (setvar "CMDECHO" 1)
  (princ)
ACAD
10.9.2011   21634×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 15138:AutoCAD Field formatting codes - full list.
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 13831:ReplMTcol - recoloring parts of text in paragraph Mtext.
Tip 13006:Calculated property descriptions (tobogan slide from floor to floor)
Tip 11289:Adding, multiplying and rounding numbers inside DWG drawing texts - NumInText.
Back    All CAD Tips
Categ:
