CAD tip CAD tip # 11708:
Question
Using the freeware utility TXT2BLK you can automatically convert selected single-line texts in your DWG drawing to block attributes (block references) - the blocks are inserted in the same place, with the same appearance and formatting as the original texts.
You can download the TXT2BLK utility from DL Download, load it with APPLOAD and run by typing the TXT2BLK command. Then just select the standard texts to convert. Nothing changes visually after the conversion, but instead of texts your drawing will contain objects of the type INSERT - i.e. block references (specifically the automatically created block "Txt2Blk_Block") with the filled value of the variable attribute "ATT1" (reflecting the original text string value). These blocks can be then included in standard workflows of attribute export and similar processes.
The command TXT2BLKZ will add elevation text based on the text's Z coordinate.
If you predefine your own block "Txt2Blk_Block" or "Txt2Blk_BlockZ", the conversion tool will use the geometry of this block (instead of plain text).
ACAD
30.11.2017   27347×
this tip shared by ARKANCE experts applies to: ACAD ·
Tip 15138:AutoCAD Field formatting codes - full list.
Tip 15102:DBXscan/DBXrem batch utilities for AutoCAD
Tip 14690:Text copied from EATTEDIT is pasted as RTF.
Tip 14630:Extended ASCPOINT - import coordinates from CSV file, including blocks with attributes, GPS coordinates, etc.
Tip 14604:QRcode - dynamically generated QR codes in AutoCAD.
Back    All CAD Tips
Categ:
